one of our Pearls is always in “Overall system load: 98%”. It has become unusable. I tried with a factory reset but it not solved. When I try a disk check, the output is:
Started disk check id 1739 on Tue Jul 10 07:00:25 EDT 2018
cannot mount /dev/sda5 /data
cannot unmount /data
Do you think I should send for repairing? we bought it more than two years ago.
Thanks for support!
