New X2 user and I have a couple of questions:
I used my cellphone to pair with Webcaster to Facebook using the code displayed. Now if I want to add another user is it the same procedure? We are both Admins on the facebook page.
Also I connected to an older monitor we have that is not wide screen. I am not able to see the whole menu and can’t scroll left or right. I went thru the settings but can’t find where I can change the resolution. Any ideas?
Thanks,
Ray
You can only have one Facebook account paired at a time to a Webcaster X2. You can’t have multiple users. When switching to a different account you would need to unpair, and then pair the new account.
The output resolution can’t be changed, perhaps there is a setting on your monitor that will scale the image to fit properly?
Thanks. I guess it really doesn’t matter which one of us sets up the account on Webcaster. Once it’s set it will automatically cast to that Facebook or YouTube account.
Actually I found a way to change the output resolution. It is under settings and HDMI output.
