this is a pre-purchase question.
If I were to connect an USB audio source with eg 48 channels (an audio mixer) could I access all those channels and assign them or is the USB audio input limited to 2?
Best,
Daniel
Best,
Daniel
USB audio is supported only if the audio mixer is UAC standard. This would mean no proprietary drivers or software required. The USB audio would simply be the Stereo master output from the mixer itself captured into Pearl
That means stereo only - no more channels even if they are delivered without any drivers.
Correct. Your output would only support stereo, but that does not stop you from capturing 48 individual channel inputs into the mixer and sending the summed output through the main stereo out.
That is correct but doesn’t help if I want to stream 5 different languages to 5 different rtmp endpoints. Unless i use the Combined inputs on the device.
