This is a Sample. Don’t forget that you can also pickup ambient noise. By using something like the Zoom 4h recorder you can also adjust levels and pickup minimal air noise. https://youtu.be/EtlBD2GKZJA
USB audio adapter works good on my device, as i install with the help of Fix Error code 0X0070002 which is the best suggestion for me and for the webcaster x2.
Hi all?
Is it possible to have a USB camera without audio like Svpro USB Web Camera and a USB Stereo capture like https://www.amazon.es/V-TOP-Convertidor-Cassette-MP3-Conversor/dp/B00XU4NT6K/ref=sr_1_13?__mk_es_ES=ÅMÅŽÕÑ&keywords=usb+audio+capture&qid=1572527462&sr=8-13 ?
Sorry no, the Webcaster can only use one USB input device. If you need USB video, HDMI video, and then analog audio I would recommend instead using an HDMI audio embedder / HDMI audio inserter to get the analog audio into the HDMI feed.
Just wondering if anyone has used a Behringer XR18 on USB audio with the Webcaster X2? This would be really sweet as you could mix a full band and send a stereo mix straight to the livestream.
Wonder if USB Audio would work with Behringer Xenyx 1204USB mixer?
I can confirm that it works with my Behringer U-Phoria UM2. Unfortunately, even with the pre-amp, I’m still not getting enough audio volume while streaming or playback via Facebook.
We tried the Monoprice hdmi audio injector, and Behringer seems louder, but pushing out board to clip point, the UM2 to clip the improvement is marginal, and our videos are still too quiet. Does anyone have any suggestions?
